Overheating
2001 LAND ROVER RANGE ROVER
128,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
KYLE B
I have the vehicle listed above and it ran really good, my wife was driving it one day (we use it as a spare car) to pick up the kids, and it starting to overheat. She stopped, pulled over waited for it to cool down, she eventually made it home. I looked and it was leaking coolant. I though it was the water pump, so I replaced it. Started it up and it had a leak still. I found that the throttle body heater hose was cracked and leaking. Replaced it. Took the vehicle out for a test drive, it overheated. Long story short, I replaced the thermostat, coolant reservoir, radiator, fan clutch, hoses, water pump. I do not know what to do now. It does not necessarily overheat in idle, it overheats driving over 30 mph. I checked the oil, no water or coolant, and no power loss and no white exhaust. When I refilled the coolant it took a little over three gallons. I am running out of ideas. Help please!
Oct 24, 2018 at 3:56 PM
Do you know where the coolant is going is it getting forced out when the engine overheats or do you see it on the ground? It sounds like it could be a blown head gasket still even though you have no white smoke or coolant in the oil. Here are two guides to go over to see what's going on.
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please run down these guides and report back
Oct 26, 2018 at 10:50 AM
