Cannot turn ignition on, BCM replace, and it was still doing the same?
2011 LAND ROVER RANGE ROVER SPORT
116,574 MILES • 5.6L • V8 • 2WD • AUTOMATIC
MALLYBOY
  • 327 POSTS
This vehicle started this problem after being pack for seven years and came back to start the vehicle and this vehicle started this problem. what's the cause of this problem?
Mar 20, 2024 at 4:54 PM
Take a look through this link first and let me know if anything is helpful. If not, the cylinder may need to be replaced. Additionally, make sure the battery is fully charged.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Also, please confirm the engine size for me. No 5.6L is an option. The sport comes with a 5.0L.
Mar 20, 2024 at 6:17 PM
MALLYBOY
  • 327 POSTS
cylinder may need to be replaced. No, it does not use key but keyless system.
Note: Engine capacity is 5.0L V8
Mar 20, 2024 at 10:28 PM
If it is a keyless system, what cylinder are you referring to?
Mar 21, 2024 at 8:21 PM
MALLYBOY
  • 327 POSTS
It is from your previous post "If not, the cylinder may need to be replaced. Additionally, make sure the battery is fully charged". What are you referring to by cylinder need to be replaced?
Mar 21, 2024 at 9:28 PM
When you indicated you couldn't turn the ignition, I assumed it had a traditional type key. I was unaware it was a push-button start.
Mar 22, 2024 at 8:47 PM
MALLYBOY
  • 327 POSTS
I was unaware it was a push-button start. Yes, it was a push-button start.
So, what will I do in this situation?
Mar 22, 2024 at 8:57 PM
Because it is a push-button start, the first thing I would do is check for diagnostic trouble codes. Scan the can-bus to see if there is anything stored.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know if that is something you have already done.
Mar 22, 2024 at 9:31 PM
MALLYBOY
  • 327 POSTS
How can you scan a vehicle that when you press the push-button, no light will appear on the dashboard showing that ignition was turned on?
With the new BCM installed and push-button pressed, a light will flash saying "key not found".
Mar 22, 2024 at 11:32 PM
When you replaced the BCM, did you restore communication to the CJB and update/program the new module?
Mar 23, 2024 at 7:03 PM
MALLYBOY
  • 327 POSTS
Can program a module when the ignition is not turned on, everything I am doing now is for ignition to turn On. Use the ignition diagram to check how to turn ignition on before programming.
Mar 24, 2024 at 1:41 AM
I don't know if it will help you or not, but I attached the wiring schematic for the starting system. It appears everything comes from the BCM.
Let me know if this helps.
See pic below.
Mar 24, 2024 at 6:05 PM
