By replacing the distributor, you basically have covered everything related. However, did you do anything with the ignitor? The igniter physically fires the ignition coil in response to the ECM signal. The igniter is essentially an electronic relay. It receives a "trigger" from the ECM and responds by turning a higher amperage current to the ignition coil on and off signaling ignition fire (spark at the plugs). It should be mounted above the power brake booster.
The igniter physically fires the ignition coil, so this is my first suspect. I attached the wiring schematic of the ignition system below so that you have a reference. Note that the ignitor (ignition control unit) will have a 5-pin connector. I found a pic of one online and attached it as well. (Pic 2).
If you haven't already, scan the computer for diagnostic trouble codes. This has an OBD1 system and doesn't require a scan tool to retrieve codes. Follow this link:
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
One last thought. The manual indicates the part to be above the brake booster. For some reason, I remember it on the left strut tower. Check both areas. It should be somewhat close to the coil.
See pic below.
Jan 19, 2023 at 7:43 PM
