Hey LILFROST187,
When it leaks can you check the color of the oil and report back?
Engine oil will be a blackish golden color depending when it was last changed and power steering and transmission fluids are generally red.
Take some pictures if you can and we will help you identify the oil type.
Have you jacked up the vehicle and visually inspected for leaks?
Guide on jacking up vehicle below:
Be very careful when getting underneath a raised vehicle, you must ensure it is supported safely.
If you are not comfortable doing this a shop will not charge much just to put it on a hoist and do a visual inspection for leak.
If you find a suspect area send some picture and we will try and work you through what is causing the leak.
Regards, Joe
Mar 24, 2019 at 9:54 AM
