Random misfire code P0300
1999 CHEVROLET SUBURBAN
210,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RASLINMASTER
  • 5 POSTS
Was getting a code saying the number five cylinder had a misfire. I chased that problem by installing new plugs, wires, cap, rotor, and new fuel injector to number five cylinder. Now I am getting a random misfire code. The truck barely runs, will backfire when I try to give it gas, and will not go over thirty mph. Could I have a bad distributor, coil, maybe a bad timing chain? Please help!
Sep 13, 2017 at 10:26 AM
MHPAUTOS
  • 31,937 POSTS
check for vacuum leaks and certainly look into a new coil as well, or see if you can get an oscilloscope test as this will check the ignition voltages to see if there is a problem there first.
Sep 14, 2017 at 5:04 AM
RASLINMASTER
  • 5 POSTS
How do I rule out a bad time my chain? MAF? It has backfired a few times and once when I went to start it I hear a loud clunk and then try again and it cranks fine.
Sep 14, 2017 at 1:44 PM
It sounds like you may have lost the timing chain. We can confirm by doing a compression test.
Here is a guide to help you get started.
You can rent a gauge for free at most auto parts store.
Please let us know what you find.
Sep 15, 2017 at 4:28 PM
