I started getting some really bad misfiring on the way to work one morning. I used my code reader and picked up a P0301 and then P0300. So I went and got a spark plug to change the one on cylinder one. After doing so the engine still ran rough. I decided to change all of them and coming onto the third cylinder I found oil in the well. The plug was fairly saturated with oil. This was the only one like it. After reading about possible causes, it seems that I will have to remove the valve cover to replace a gasket for the spark plugs. Is there any information as to what exactly would need to be done? I usually do most of the work on my vehicles but do not really know the starting point for this job.
Jun 9, 2018 at 9:24 AM
