Random misfire and codes P0300, P0303 and P0304
2012 VOLKSWAGEN TIGUAN
74,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
MILINTHOSANI
I am getting P0300 P0303 and P0304 error codes.
I changed all the spark plugs and Ignition coils. Still I see the same problem. Please help.
Jul 31, 2020 at 6:26 PM
These codes can be the result of a few things. Engine vacuum leaks, fuel pressure, along with other things can cause them.
Since the vehicle only had 74,000 on it, I can't imagine it is a compression issue. So, lets start by checking to see if there are any leaks that could be causing it. Here is a link that explains how to check for engine vacuum leaks:
Also, make sure the air induction tube between the air box and the throttle body is properly installed.
Let me know what you find
Jul 31, 2020 at 10:15 PM
