random misfire
1997 FORD ESCORT
115,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
DONPRUETTE
  • 5 POSTS
my car is jumping occasionally and I had just replaced the plugs and wires with correct type and gap. Still jumping but not as bad. an obd reading said random misfire . next step is replace the coil pack, but am also having trouble with temp. guage . Could it be coolant sensor, since it would possibly cause a misfire and also guage trouble?
Jan 20, 2016 at 12:48 AM
JOHNNYT73
  • 924 POSTS
That could be a possibility. A bad temp sensor can cause the vehicle to usually run very rich. You can check the coil. I would also suggest that since it is a random misfire code that to check your fuel pressure, fuel filter, and that your engine did not jump time on the timing belt.
Jan 20, 2016 at 5:56 AM
