Vehicle listed above is a non-turbo. . Problem: Random misfires for the last 4 years. No OBDC codes showing, ever. Scanner always shows everything okay. Problem is not temperature related, either ambient: 40ºF - 120ºF, or engine. Also, no correlation to gear selection or shifting. Charging system okay. Problem can appear immediately after starting or not show for 60 miles. Somewhat sensitive to throttle and load, but not always. Re-seated four connectors to ECM, problem still appeared after 30min drive on level ground. Computer engineer (hardware) with DVM, but no oscilloscope. Ideas? Larry
Mar 28, 2021 at 9:28 PM
