Good morning.
the fuel pump should only run 2 seconds for priming.
It sounds like you have an issue with the ECM. The scan tools for the old systems did not give a lot of information for diagnostics.
Based on these results, it sounds like you need an ECM.
It is located in the right lower kick panel. I attached a picture for you.
The Electronic Control Assembly (ECA) stores information about vehicle operating conditions and uses this information to compensate for component tolerances. When an emission related component is replaced, Keep Alive Memory (KAM) should be cleared to erase the information stored by the processor from the original component.
To clear the KAM, disconnect the battery negative terminal for five minutes or more. Drive the the vehicle for at least ten miles to allow the ECA to relearn the values for optimum performance.
NOTE: During the ten mile relearn drive, the vehicle may exhibit some driveability symptoms. These should be eliminated when the KAM has relearned the operating values.
Mar 2, 2021 at 7:01 PM
(Merged)
