Radio has sound when key is out and door open
2002 LEXUS LS 430
180,000 MILES
BLACK430
Key out door open radio has sound. no controls operate on radio. If you turn key in ignition back/forth a few times it will stop playing. ignition switch has been replaced. Same results. Drains the battery as well. Alternator is charging. Could the ignition cylinder be the issue since back/forth stops the sounds?
YouTube link:
https://youtu.be/tk4-_14eZGA
Mar 1, 2017 at 12:40 PM
HOPPY313
  • 8 POSTS
I had this happen in my Chevrolet Malibu once. I was at a sporting event, and had some down time. I sat in my passenger side with the door open since it was facing downhill. In my case, you can sit in the passenger side, and turn the ignition to get radio power/on. It will stay on, even after removing the key. It seems to only respond to opening and then shutting the driver side door (to shut it off). Passenger door open/closed does nothing.
That is my guess. I do not fix cars, I just pay for them. Try that next time? Good luck.
Mar 2, 2017 at 10:19 AM
Hey,
This sounds like it is going to be a problem with the gateway ECU which controls the power to the radio.
Here is a wiring diagram so you can remove the radio and do some testing to see if the power shuts down from the ECU.
Also, check the fuses in the system the wiring diagram shows which ones to check.
and
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Mar 2, 2017 at 5:44 PM
