This has happened within the past few months the radio and clock quit working. then the power door locks quit working with the key fob. then with the door lock/unlock switch (unless van is running). can't open lift gate unless van is running, no interior lights work unless the van is running and shut off immediately when van is turned off. Driver/passenger power windows won't go up or down. Are these all fuse issues? If so which fuses? If window motors and/or regulators need replacing, approximately how much will that cost? Thanks!
Nov 10, 2020 at 9:09 PM
