Changed both batteries and got it running good, but the A/C unit does not power on at all, blower stay on after car is off. You can hear it come on for a second and go off, and keeps repeating the cycle, that's why the batteries drained, so I unplugged the blower for now. Found a 7.5-amp radio fuse behind passenger side that was bad, changed it and the screen now comes on and then says unavailable and shits off, keeps doing that. I'm not sure if the A/C unit issue is related, where is the fuse for the A/C unit as I don't have the diagram or chart for it. maybe a fuse. I also get the red light for battery on dash when I start the car even though charging is over 14 and both batteries are new. I load tested trunk battery and its good, front is new from Benz, when I clear the code for the light it goes away but next time, I start the car it shows same light.
May 17, 2024 at 10:47 AM
