Have you checked to see if the fuse has failed? Also, are there any other electrical components that are not working?
The fuse for the radio is in the vehicle's instrument panel fuse block which is located on the passenger side of the vehicle, on the lower portion of the instrument panel center console near the floor.
I need you to check the fuse first to make sure it is good. If it is, check to make sure there is power to the fuse when the key is on.
I attached a pic below indicating the fuse location in the fuel box.
Let me know what you find.
See pic below.
Apr 30, 2022 at 9:14 PM
