Changed the battery now the radio will not turn on
2007 SUZUKI XL7
78,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
PHIGHLAND28
  • 6 POSTS
Also the door ajar chimes and seat belt chimes do not work.
Sep 14, 2019 at 1:31 PM
Welcome to 2CarPros.
The first thing to check is the radio fuse. It is located in the interior fuse box. I attached a picture showing the location of the fuse.
__________________
Here are a few links to help:
https://www.2carpros.com/articles/how-a-car-fuse-works
_________________
Let me know what you find.
Sep 14, 2019 at 9:26 PM
PHIGHLAND28
  • 6 POSTS
I have checked the radio and amp fuse they where both good. can't get CD player out to check the fuse in the back of it. but so far all fuses in both locations looked good.
Sep 15, 2019 at 6:52 AM
When you turn the radio on, does anything happen? Any lighting?
Sep 15, 2019 at 3:14 PM
PHIGHLAND28
  • 6 POSTS
No nothing at all.
Sep 15, 2019 at 3:19 PM
At this point, the only thing you can do is confirm power to the radio. If the fuse is good and there is power to the radio, possibly an internal fuse has failed, the on/off switch has failed or the radio has failed.
Let me know if you can confirm power to the radio itself.
Sep 15, 2019 at 7:54 PM
PHIGHLAND28
  • 6 POSTS
It had power up to the radio got it out radio wouldn't power at all still so guess radio failed.
Sep 16, 2019 at 6:07 AM
PHIGHLAND28
  • 6 POSTS
Thanks for the help.
Sep 16, 2019 at 6:08 AM
Welcome back:
If there is power to it, then either an internal fuse in the radio has blown, the switch has gone bad, or the radio is bad.
I wish I could have had a better answer. Let me know if I can help in any way.
Sep 16, 2019 at 7:07 PM
PHIGHLAND28
  • 6 POSTS
There was no fuse in the radio at all. so radio must have went. thanks for your help.
Sep 17, 2019 at 11:46 AM
You are very welcome. Let us know if we can help in the future.
Sep 17, 2019 at 6:44 PM
