Did you reinsert the fuses properly from where you took them out?
See image 2 below I marked the fuses which supply the infotainment system, marked in yellow. Note that not all fuses might be present, depending on the vehicle's equipment level.
A good source of fuse information:
https://fuse-box.info/chevrolet/chevrolet-equinox-2010-2017-fuses-and-relay
With display I assume you are talking about the info/navigation display?
Fuse F15DA (10A) supplies power to this module
Also while going over the wiring diagrams, I found another fuse, fuse F9DA (20A).
I would think that this is the fuse which you had checked in the beginning, see image below.
If all fuses are inserted where they should be, and none have blown, I would suggest carrying out a battery reset. This entails disconnecting the battery at the negative terminal and leaving it disconnected for several minutes. Then reconnect the terminal, ensuring that it is tightened properly.
How to:
https://www.2carpros.com/articles/step-by-step-guide-how-to-reset-an-automotive-battery-monitor
This procedure is for the battery monitor but also applies for a reset.
Cheers, Boris
Jul 23, 2023 at 12:11 PM
