Hi and welcome back:
Here is everything I have on removal and install. Let me know if it helps. By the way, all attached pictures correlate with these directions.
______________________________
Radiator
Removal
Note! Removal steps in this procedure may contain installation details.
Remove the following items:
- Cover bumper front Refer to: Cover bumper front See: Front Bumper Cover / Fascia > Removal and Replacement Cover bumper front See: Front Bumper Cover / Fascia > Removal and Replacement
- engine cooling fan (FC) Refer to: Engine cooling fan (FC), B6324S4 See: Radiator Cooling Fan > Removal and Replacement > Engine Cooling Fan (FC)
Perform cooling system draining, charging and bleeding Refer to: Cooling system - draining, charging and bleeding, B6304T4, B6324S5, B6324S4 See: Cooling System > Procedures > Cooling System - Draining, Charging And Bleeding
Warning! Be prepared to collect escaping fluid.
Remove right headlight Refer to: Headlamps See: Headlamp > Removal and Replacement > Headlamps
Torque: Radiator to condenser, 5 Nm
999 5463 FIXTURE See: Vehicle > Electrical / Mechanical Repair > 999 5463 Fixture
Torque: M8, 24 Nm
Installation
To install, reverse the removal procedure.
___________________
Dec 22, 2018 at 12:39 PM
