Good afternoon,
I attached the procedure below for the radiator replacement.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
https://www.2carpros.com/articles/replace-radiator-hoses
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Yes, replace both hoses and the thermostat as well.
NO.2 RADIATOR ASSEMBLY
REPLACEMENT
1. DRAIN COOLANT
2. DISCONNECT RADIATOR HOSE INLET
3. DISCONNECT RADIATOR HOSE OUTLET
4. DISCONNECT OIL COOLER INLET HOSE NO.1
5. DISCONNECT OIL COOLER OUTLET HOSE NO.1
6. REMOVE FRONT BUMPER COVER
7. REMOVE AIR CLEANER CAP SUB-ASSEMBLY
8. REMOVE AIR CLEANER FILTER ELEMENT SUB-ASSEMBLY
9. REMOVE AIR CLEANER INLET NO.2
10. REMOVE AIR CLEANER CASE
11. REMOVE AIR CLEANER BRACKET
12. REMOVE AIR CLEANER INLET NO.1
13. REMOVE HOOD LOCK RELEASE LEVER PROTECTOR
a. Release the 4 claws and remove the hood lock release lever protector.
14. REMOVE HOOD LOCK ASSEMBLY
a. Remove the 3 bolts and separate hood lock.
15. REMOVE RADIATOR SUPPORT SUB-ASSEMBLY UPPER
a. Disconnect the horn connectors.
b. Remove the 5 bolts and the radiator upper support.
16. REMOVE FAN SHROUD
a. Disconnect the engine coolant reservoir hose.
b. Disconnect the fan motor connector.
c. Remove the 4 bolts and the fan shroud.
17. REMOVE RADIATOR SUPPORT SUB-ASSEMBLY UPPER LH
a. Remove the 3 bolts and the radiator support upper LH.
18. REMOVE RADIATOR SUPPORT SUB-ASSEMBLY UPPER RH
a. Remove the 3 bolts and the radiator support upper RH.
19. REMOVE RADIATOR SUPPORT SUB-ASSEMBLY LOWER RH
a. Remove the 3 bolts and the radiator support lower LH.
20. REMOVE RADIATOR SUPPORT SUB-ASSEMBLY LOWER RH
a. Remove the 3 bolts and the radiator support lower RH.
21. REMOVE NO.2 RADIATOR ASSEMBLY
22. INSTALL NO.2 RADIATOR ASSEMBLY
Thermostat
THERMOSTAT
REPLACEMENT
1. DRAIN COOLANT
2. REMOVE BATTERY
3. REMOVE AIR CLEANER CAP SUB-ASSEMBLY
4. REMOVE AIR CLEANER FILTER ELEMENT SUB-ASSEMBLY
5. REMOVE AIR CLEANER INLET NO.2
6. REMOVE AIR CLEANER CASE
7. REMOVE AIR CLEANER BRACKET
8. REMOVE AIR CLEANER INLET NO.1
9. REMOVE STARTER ASSEMBLY
10. DISCONNECT RADIATOR HOSE OUTLET
11. REMOVE WATER INLET
a. Disconnect the wire harness clamp.
b. Remove the bolts, the 3 nuts and the water inlet.
12. REMOVE THERMOSTAT
Mar 17, 2021 at 3:35 PM
