Radiator removal and installation
2001 CADILLAC SEVILLE
149,000 MILES • V8
DOUGPARKS567
  • 60 POSTS
How do I remove a damaged radiator off the car listed above SLS model?
Nov 24, 2019 at 11:00 AM
Here is the procedure from the book. Let me know if you need more info. Thanks
Nov 24, 2019 at 5:53 PM
DOUGPARKS567
  • 60 POSTS
Thanks for reply! but I need to know how I remove radiator also.
Nov 25, 2019 at 1:59 PM
That was the process for the radiator. It says condenser but this is a complete assembly. The condenser is on the radiator. You should see the AC lines attached to the side along with the cooling lines. I circled the coolant inlet and put a square around where your AC lines should be.
Nov 25, 2019 at 6:36 PM
