Radiator problem
2007 LEXUS RX 350
150,000 MILES
GABBYDELGADO1769
The cap to my radiator has an outgoing plastic piece to a hose that hose has disconnected due to the piece that was connected that was plastic has broken or melted or disconnected. is there anyway I can fix it without replacing the whole radiator itself?
Nov 7, 2017 at 12:08 PM
WRENCHTECH
  • 20,761 POSTS
I don't think so. I have had to replace many a radiator for that reason. That is a pressure connection and no type of epoxy will hold.
Nov 7, 2017 at 2:44 PM
GABBYDELGADO1769
I had a mechanic come and check it out and yes that part is and was replaced. it is called, coolant filler neck for anyone who also needs help.
Nov 7, 2017 at 6:09 PM
You can repair this kind of repair if you drill and thread a brass hose fitting into the end of the hole on the neck. I have never seen a replaceable filler neck but there is always a first.
Here is a guide on what you are in for when replacing the radiator:
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
Nov 9, 2017 at 2:52 PM
