Radiator pressurized air?
2018 NISSAN MAXIMA
66,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
EDINAVDIC123
I have the car listed above, American specs at 106,000KM currently. Recently I had to do bypass on the heather core since it started leaking and heating is really not needed where I live. However, I have noticed now when the engine is cooled overnight, and I open radiator cap pressurized air with a bit of coolant goes out through reservoir overflow that causes me to need to add a bit of coolant in radiator.   I have changed the thermostat, checked the water pump, replaced the radiator cap as well with a genuine one.  However, the issue is still there.  I thought it could be gasket, but I don't have any sign that could state that except that air by the way it lasts literally a second after I open radiator cap.  Don't have overheating, no white smoke, checked oil, no bubbles in coolant nothing at all to point me out in right direction.  Any ideas?  Or think that is gasket?   Thank you
Jul 8, 2024 at 7:41 AM
If you have pressure in the cooling system overnight this can be normal. Especially since you have no other issues. I would let it go; the radiator cap regulates the pressure, so you are safe. If I missed something let me know and upload images.
Jul 8, 2024 at 11:41 AM
