Radiator leak
2001 CHEVROLET IMPALA
158,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
CILS2001
Some coolant on the ground each time driving a short distance.
Nov 22, 2019 at 7:46 PM
CILS2001
I may have found the problem. There is a port with a cap on it that I
seem to have tightened as while turning this cap it made a tightening
sound. This is at an area in proximity of the bottom of the radiator
on the driver's side. Is this correct to what you know about this radiator? Is this one of the possible coolant leak symptoms that I may have corrected?
Nov 22, 2019 at 7:57 PM
It sounds like you tightened the drain. It could leak from there is it was loose. Here are a few links you may find helpful. Take a look through them and let me know if they help.
https://www.2carpros.com/articles/car-is-leaking-coolant
Next, to find a leak, the best thing to do is pressurize the cooling system and then check. If there is a leak, the pressure is likely to cause it to leak. You will need a pressure tester, but most parts stores will lend / rent one to you.
https://www.2carpros.com/articles/radiator-pressure-test
Let me know if that helps.
Nov 22, 2019 at 10:06 PM
CILS2001
Thank you so very much for your reply. That plug on the bottom of the radiator appears tightened and I have no new leaks over some time now. You guys are so kind in helping me out. I am so grateful. Thanks again. Carl England
Nov 22, 2019 at 10:29 PM
Carl, you are very welcome. Feel free to come back any time.
Take care and have a good weekend.
Nov 22, 2019 at 10:32 PM
