radiator fans not working
2007 KIA CARNIVAL
200,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FLIDERSPARK
  • 4 POSTS
radiator fans stopped working.
problem found was thermostat was stuck closed it's now been open freely).
replaced ECT.
replaced fan controller on top on left fan.
if i unplug ECT fans run very high as soon as plug ECT fans stop.
is there anything else to check being faulty?
Nov 4, 2021 at 6:31 PM
The fan will default to on with no signal from the sensor. Have you checked the fan relay? I realize you replaced the cooling fan module, but the relay could also be faulty.
Next, the Carnival isn't offered in the US, but I believe it is the same as our Sedona. So, that is where I am gathering my schematic/electrical info.
I attached the schematic below for the Sedona. Locate the relay on your vehicle and switch it with a different one having the same part number. If there isn't one, here is a link showing how to inspect one:
I attached the schematics I have below. I had to cut it in half to make it readable for you, but I did overlap them so you can follow from one to the next.
Let me know if this helps.
See pics below. Also, pic 3 shows the relay location.
Nov 4, 2021 at 8:36 PM
FLIDERSPARK
  • 4 POSTS
Hi Joe, thanks for response, i have actually replaced relay as well which is located near battery.
would there be any other sensors from engine etc., as when i fan stooped working and car started overheating it was misfiring a lot and had too many codes. unfortunately, i don't have record of those codes anymore.
Nov 4, 2021 at 11:26 PM
Do me a favor. If you look at the schematic below, I highlighted a fusible link that sends power for the fans. See if there is power at the white wire for the relay.
A fusible link looks like a wire, but functions as a fuse. Check that.
See pic below.
Nov 5, 2021 at 6:37 PM
FLIDERSPARK
  • 4 POSTS
that fusible link is fine, i can see power going to fan controller module.
so, there are two connections to fan controller 1: single wire 2: 3 wires.
single connections wire has power but nothing from plug with three wires.
Nov 5, 2021 at 11:29 PM
FLIDERSPARK
  • 4 POSTS
i have added schematic picture highlighted, should i be checking two relays in engine compartment?
Nov 5, 2021 at 11:42 PM
Yes, the main relay needs checked. If there is a different relay with the same part number, switch them. If there isn't, here is a link that explains how to test a relay:
Let me know what you find.
Nov 6, 2021 at 8:45 PM
