Radiator fan will not turn on
2004 JEEP GRAND CHEROKEE
18,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
WITCH1
  • 15 POSTS
Vehicle listed above is a Laredo 4.0l straight 6 4x. Overheating because radiator fan stopped working. After I changed radiator, cap, thermostat, hoses, modules, water pump, temperature sensor. Fan will turn manually, bypassed it directly to battery still would not come on. Now question is, do I have to buy entire radiator fan assembly, or can I buy just electrical plug and or fan motor? Last this would be the problem since fan wouldn't turn on when wired directly, right?
Thank you for any input.
Jun 17, 2021 at 2:25 AM
Good morning,
I attached a diagram for you to view for the cooling fan motor.
You will need to replace the entire assembly for the fan motor if you applied a direct current to the motor and it did not work. I attached diagrams for you for the procedure below.
https://www.2carpros.com/articles/replace-electric-fan-motor
Did you replace the dual control fan relay module? I also posted the procedure for you as this is a common failure.
Jun 17, 2021 at 3:08 AM
WITCH1
  • 15 POSTS
Yes, I did check and relays were good.. bought entire radiator fan assembly. Just have to put it in. It was 116 in Vegas today.....
Jun 17, 2021 at 10:03 PM
Okay, good. I assume you verified the voltage to the fan motor from the relay. Make sure you have voltage at that connector. That electronic relay was a very common failure for the fan not working.
Jun 18, 2021 at 1:32 AM
WITCH1
  • 15 POSTS
Yes, it read 12v.
Jun 18, 2021 at 2:39 AM
Good. Then replace the fan. Just wanted to be sure.
Jun 18, 2021 at 2:53 AM
WITCH1
  • 15 POSTS
Thank you so much! I'll let you know how it goes...
Jun 18, 2021 at 1:32 PM
WITCH1
  • 15 POSTS
Wait quick question. Does it matter what kind/brand fan I buy? Can I get universal or not?
Jun 18, 2021 at 2:01 PM
You are welcome.
Always glad to help.
Jun 18, 2021 at 2:28 PM
No to universal. They are tough to mount and wire.
I attached the part I would use from Rock Auto.
Jun 18, 2021 at 2:30 PM
WITCH1
  • 15 POSTS
Problem! Put new fan in. It's not fan. No power coming to fan. Relays are good.
Jun 20, 2021 at 3:05 PM
You stated there were 12 volts at the fans? Was that accurate?
You need to go to the electronic relay and test for power out that relay.
If you checked the relays, how did you check them? Does the dark green wire have power?
I already posted the guides for testing in my original response.
Jun 20, 2021 at 4:12 PM
WITCH1
  • 15 POSTS
Forgive me I did not see all the posts and pics they are going to be very helpful tomorrow when I start from scratch again. The problem is it's 100 degrees at 10:45 pm. daytime temperatures reaching over 118. And I'm just a girl (no offense to other females). But no matter how hard I research I do not understand electrical. And this town is famous for so-called mechanics. I am going to have to go to Angie's List or look for a credible mechanic/electrical. do you have any pointers on how to find one, like ASE Certified? I'm not sure what to look for, but I can research the heck out of anything. So I guess I can say thank you so much for all your time and effort.
Jun 20, 2021 at 11:01 PM
You are welcome.
Keep me updated and let me know what they find.
Jun 21, 2021 at 1:44 AM
WITCH1
  • 15 POSTS
Thank you.
Jun 21, 2021 at 2:02 AM
Make sure they can trace the circuit by the diagram I posted for you. You need someone who can read diagrams and do pinpoint testing.
Jun 21, 2021 at 3:08 AM
WITCH1
  • 15 POSTS
Thank you. Can you tell.me exactly what to look for in an honest mechanic?
Jun 21, 2021 at 3:37 AM
Experience. He needs to have a background in electrical troubleshooting. Without that, he is guessing at your expense.
Jun 21, 2021 at 3:38 AM
WITCH1
  • 15 POSTS
Thank you again.
Jun 21, 2021 at 3:49 AM
Anytime.
Thanks for using 2 CarPros.
Jun 21, 2021 at 3:51 AM
WITCH1
  • 15 POSTS
Hi, sorry to bother you. I cannot seem to find a reputable mobile auto, electrical mechanic. One guy charges $120.00 an hour to diagnose it. I did however speak to another one told me to put radiator back in place, fill it with water or coolest. Leave radiator cap off.. Not to hook up fan. Start truck rev engine for 2 minutes if water shoots out from radiator (where cap should be) its head gasket.??? Then I'm being told there's another relay behind passenger headlight. But then there's conflicting reports that no my vehicle does not have relay behind headlight. There's 2 relays in fuse box inside hood. I have 2 relays for fan high and low speed. I don't know what to do.
Jun 21, 2021 at 9:39 AM
Okay, he is correct but that is not the reason for no voltage to the fan.
Try this: Disconnect the coolant sensor wires and turn the key on. Hook up the fan connections and see if the fan kicks on.
I attached a picture of the location for you.
Jun 21, 2021 at 1:35 PM
WITCH1
  • 15 POSTS
It's fixed!! Bad Relays and broken wire..
Jun 22, 2021 at 12:04 PM
Good find.
Glad you are back on the road.
Jun 22, 2021 at 12:25 PM
WITCH1
  • 15 POSTS
Thank you for everything!
Jun 22, 2021 at 8:08 PM
You are welcome.
Jun 23, 2021 at 2:01 AM
WITCH1
  • 15 POSTS
Well my Jeep is not fixed. The mobile mechanic ran a jumper inn the relay so fan would stay on. Which it does. But after approximately three minutes of idling, the temperature rose past 250. I had to shut it off, wait 10+ minutes and ran the heater on high to get home. I'm at a loss. It has got new radiator, hoses, thermostat, temperature sensor, fan assembly, it's not water pump. And made sure there were no bubbles in coolant lines. Any suggestions? I'm going to take out thermostat put it in pot boiling water to see if it opens...
Jun 23, 2021 at 12:22 PM
Okay, I would more suspect a head gasket than a bad new thermostat.
I would do a compression test to see if there are any air bubbles in the radiator during the test to be sure the gasket is not leaking.
You have covered all the basics with what you did but if it still overheats then the head gasket is the next check.
I attached the procedure for you below for the head gasket.
Jun 23, 2021 at 1:30 PM
WITCH1
  • 15 POSTS
No, it's not head gasket tried 3 tests. I did notice the radiator overflow which was at full mark yesterday, is almost empty. I searched for leaks can't find any...
Jun 23, 2021 at 7:43 PM
Did they do a leak-down test on each cylinder?
That is where they inject shop air into each cylinder 1 at a time and watch for any coolant movement in the radiator.
If the coolant comes up or bubbles, it is the head gasket leaking. Each cylinder needs to be tested.
My gut tells me that this is your issue.
Jun 23, 2021 at 9:15 PM
