Radiator fan relay location
2004 JEEP GRAND CHEROKEE
174,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
MARIANNA ZDINAK
I cannot find the radiator fan relay on my vehicle.
Sep 30, 2016 at 3:32 PM
WRENCHTECH
  • 20,761 POSTS
It is a two speed system that utilizes two relays. https://www.2carpros.com/images/external/107224941.gif
Sep 30, 2016 at 5:06 PM
JIS001
  • 3,412 POSTS
Just to add to it myself, CJ MEDEVAC's link should be the cooling fan module, but they call it a relay also and is behind the right side headlight. The bumper skin would need to come off to replace it. Attached image of what it looks like. Here is a link to do it without removing the bumper skin.
http://www.denlorstools.com/autoblog/2010/10/jeep-grand-cherokee-overheating-problems/
Hope this helps. Is that behind the passenger side light
Sep 30, 2016 at 6:10 PM
MICKEY
where is the radiator cooling fan relay located on a 2001 jeep grand cherokee?
Sep 12, 2019 at 12:26 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
The cooling fan relay is under the hood. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
WRENCHTECH
  • 20,761 POSTS
This one is not in the relay box. This truck uses a solid state relay and it's hidden very well.
The Pulse Width Modulated (PWM) cooling fan relay is located below the right headlamp behind the bumper fascia.
SCORPIONHILBILI
How do you locate and remove the radiator fan control relay circuit and do you have a diagram/photo of this process? Have
just purchased a Haynes Repair Manual today, but it doesn't show or tell me anything about this circuit except code #P1491, which is this relay. What a waste of time and money today, HA-HA, but will be helpful in the future, I hope. Have also purchased the relay circuit and I'm ready for home repair. Would greatly appreciate any info. Please HELP Thanks
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for using 2CarPros! Please refrain from flooding our forum, we see your first post fine it just takes time for us to get to everyone. Your vehicle's cooling fan relay is located behind the front bumper fascia, below the passenger headlamp. I have posted a diagram below.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2828.jpg
FRANK COLLINS
  • 4 POSTS
2000 jeep Grand six colling fan relay replacement.
Sep 25, 2019 at 5:20 PM (Merged)
MERLIN2021
  • 17,250 POSTS
find the power distribution center under the hood and your owners manual will have a diagram for it
if you don't have owner's manual let me know. failure can also be a temp sensor problem.
FRANK COLLINS
  • 4 POSTS
The relay is not in the box. According to Haynes (page 3-6) the relay is under the car but I can not see it from the bottom or from the top.I would like to know just where it is and how to get to it.
Thanks,
Frank
WRENCHTECH
  • 20,761 POSTS
It's located behind the headlamp on the passenger side.
REMOVAL
1. Remove front bumper and grill assembly.
2. Remove 1 support bolt near front of reservoir.
3. Remove 2 reservoir mounting bolts.
4. Remove reservoir from vehicle to gain access to vacuum hose. Disconnect vacuum hose from reservoir fitting at rear of reservoir.
5. Disconnect electrical connector at relay.
6. Remove 2 relay mounting bolts and remove relay.
INSTALLATION
1. Position relay to body and install 2 bolts. Tighten bolts to 3 Nm (25 inch lbs.) torque.
2. Connect electrical connector to relay.
3. Connect vacuum hose to reservoir.
4. Install reservoir and tighten 2 bolts to 3 Nm (25 inch lbs.) torque.
5. Install front bumper and grill assembly.
TIFFYWIFFY26
How to replace a cooling fan relay on a 1999 Jeep Grand Cherokee?
JDL
  • 16,098 POSTS
Info below.
MERLIN2021
  • 17,250 POSTS
thanks for the help guys... didn't even need the big pooter!
CARADIODOC
  • 34,306 POSTS
Which type do you have? Some models have a plug-in relay in the under-hood fuse box. You just yank the old one out and stuff the new one in. Those don't fail very often.
Some models use an electronic relay. It looks like the one in the photo below from www.rockauto.com I don't know where they live on Jeeps but on other similar vehicles they are halfway down on the driver's side of the radiator, bolted to the sheet metal beside the radiator.
WRENCHTECH
  • 20,761 POSTS
No problem Merlin
CARADIODOC
  • 34,306 POSTS
Sorry JDL. Your reply hadn't shown up yet when I posted mine.
JDL
  • 16,098 POSTS
That's fine, jump in. Have a good evening. My meds seem to be working ok.lol
