Radiator fan not working
2003 JAGUAR S-TYPE
67,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
AUSTINO
  • 220 POSTS
Good afternoon, the radiator fan is not chipping out. I don't know if the wires are connected correctly. Please help!Thanks in advance.
Jul 20, 2019 at 10:17 AM
You have two fuses and a module to check the power output here is a guide top help with the engine cooling fan wiring diagrams below.
Check out the diagrams (Below). Please let us know what happens.
Jul 21, 2019 at 4:42 PM
AUSTINO
  • 220 POSTS
Thank you, can you please tell me how to test the relay?
Jul 22, 2019 at 9:59 AM
Sure, here is a guide:
Please let us know what you find.
Jul 22, 2019 at 10:56 AM
AUSTINO
  • 220 POSTS
Okay, I will. thanks again.
Jul 22, 2019 at 12:42 PM
BEWING
The Radiator Fan does not come on when the a/c is turned on. When the car gets warm it does work normally
as well as coming on as need on a hot day when the ignitions is off.
Jul 23, 2019 at 12:09 PM (Merged)
HMAC300
  • 48,601 POSTS
check fuse 13 and 25 in under hood fuse box then have it scanned for codes there is a module that controls the fan may be bad.
JPERSICO67
my 2003 S type seems to run hot at idle. I took it for a 2 hour drive on the highway and the temp guage was at the halfway mark the whole ride. When I finally stopped and let it idle the tempature rose and the engine temp warning came on. I do not see any leaks. I don't notice any change in performance and the oil is not milky. The water pump and thermostat were replaced 6 months ago. I cant see or hear if the cooling fan is coming on or not because of it's location. The fuses look ok and the relay and fuse for the cooling fan appear to be ok but I have not tested them. (replaced the fuses). Outside tempature is roughly 65 degrees.
Any suggestions/diagnosis?
JAGTECH360
  • 74 POSTS
What engine is in this car? You should be able to hear the fan from the front of the car, especially if it is getting that hot. Has the thermostat been replaced? Could possibly be the cooling fan module.
BRITTANY021
What was the solution? Bc my 2001 V8 has the same issues.
JAGTECH360
  • 74 POSTS
Brittany, the 8 cylinders were notorious for thermostat issues. Rarely there have been waterpump impeller issues but start with the thermostat. Brian
AUSTINO
  • 220 POSTS
Hello good morning, the radiator fan is not chipping out.I tried to connect the radiator fan on a blue and white wire to try and fix it, but I am not sure if it's correctly connected. as a result can you please send me a picture showing where the little blue and white wire connect to? Please note that in the pass you sent me a wiring diagram for the fan but I don't understand how to read it. So can you please send me a simpler picture that is easier to read if you can?Thank you.
Aug 6, 2019 at 12:05 PM (Merged)
AUSTINO
  • 220 POSTS
Hello, just want you to know that I fixed the radiator cooling fan and it is now working normally as it should .I solve the problem when I discovered that a wire in the wire harness was damage as result I fixed that wire and make the necessary connection.Thank you again for all your help!
Aug 10, 2019 at 3:39 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Aug 12, 2019 at 10:26 AM
AUSTINO
  • 220 POSTS
Okay, thanks.
Aug 12, 2019 at 4:11 PM
