Radiator fan not working after replacement?
2015 DODGE JOURNEY
158,445 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROMAN913
I replaced my radiator fan because it kept blowing out my relay fuses. it didn't turn on at all. I changed the relay fuse, still nothing. I replaced the coolant sensor, nothing either. Can you suggest what is next, maybe the radiator fan switch?
Jul 17, 2023 at 10:19 AM
You may have a defective radiator fan, here are the wiring diagrams so you can see how the system works, I would start by checking the fan motor ground. Here is a guide that can help test for power and the ground (G904A) connections:
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 17, 2023 at 6:02 PM
