Radiator fan not spinning and smoking
2015 DODGE CHARGER
95,600 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JUSTINSTAATS
My radiator fan is not spinning when I have my car on and when I start the car there is a sweet smelling smoke coming from under the hood. Cannot locate the source of the smoke but sometimes I also smell a burning rubber smell.
Dec 28, 2019 at 6:58 PM
The sweet smell sounds like coolant. If you see steam, there is most likely a leak or the engine is overheating. If the engine isn't getting hot enough to turn the cooling fan on, that could be why it is not running. Let me know if the temperature gauge is indicating the engine is running hot.
Lets start easy. Lets look for a coolant leak. Never open the cooling system when the engine is hot. Always wait until it cools off.
First, make sure the engine coolant is full. Next, follow this link:
https://www.2carpros.com/articles/car-is-leaking-coolant
If you are still unable to locate the leak, you will need to pressure test the system. You will need a pressure tester. I realize most people don't own one, but often times, a parts store will lend one to you. Here is a link that explains how that is done:
https://www.2carpros.com/articles/radiator-pressure-test
Let me know what you find. Also, let me know if you can tell approximately where the steam is coming from, if the system was low, and if the engine is running hot.
I will watch for your reply.
Dec 28, 2019 at 10:16 PM
