Radiator fan loud and does not shut off with engine off
2009 DODGE JOURNEY
90,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
LOAKOAN
Radiator fan sounds like a jet engine, out of the blue, and stays on after ignition is off. Have to pull fuse to make it stop. Replace fuse after a cool down and fan is off. Does not come back on until engine temperature warms up.
Tried two new relays, disconnected negative battery cable. Still occurring. Ordered a resistor, will change that tomorrow, then possibly a coolant sensor? I do not understand the correlation between super loud and not shutting off? seems like two different issues to me. Any help would be appreciated.
Jan 22, 2018 at 5:30 PM
This car has two engine coolant sensors which it sounds like one has shorted out. Here is a wiring diagram for the radiator cooling fans so you can see how there work. Here is a guide to help you see what you are in for when changing the coolant sensor.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here are the engine coolant sensor locations (below)
I would run the codes as well to see what comes up.
Jan 24, 2018 at 12:50 PM
