Radiator fan does not turn on
1986 HONDA CRX
245,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
HBONILLA
Already checked radiator fan relay, okay, replaced thermosensor above oil filter, okay, noticed when i ground blue wire from relay, radiator fan turns on. any idea? There is a sensor on the bottom of the radiator is that part of the radiator fan system? Please advice. Thank you.
Apr 28, 2019 at 6:22 PM
SCGRANTURISMO
  • 4,897 POSTS
The blue goes to the radiator fan timer on the top of left kick panel. It provides a ground path to the radiator fan relay control side of the relay (electromagnet that pulls the switch closed when energized), and pulls switch closed, completing the circuit to the fan motor providing battery voltage so it runs. Therefore the problem is going to be with the fan timer. In the diagrams down below I have included a exploded view of your vehicle's cooling system, along with wiring diagrams and fluid charts for you. Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Apr 28, 2019 at 8:49 PM
HBONILLA
Mr Alex, thank you for you're support. it has been so hard to find answers or solutions to this problem. I really appreciate you're time and help, this is a great day.
Thank you a lot.
Will keep you posted.
Herbert Bonilla.
Apr 29, 2019 at 8:15 AM
You are welcome, SCWICKEDSTANG is one of our newest experts, he is quickly shaping up to be one of our best! Please let us know what you find. We are interested to see what it is.
May 1, 2019 at 1:08 PM
HBONILLA
I will, thank you again, very kind of you guys.
May 4, 2019 at 4:56 AM
