Radiator fan did not kick in
2008 HONDA STREAM
85,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
WAN_DOOHAN
Hi. Found out yesterday that the radiator fan did not kick in even when coolant temperature hits 109 degrees Celsius. This is when the A/C switched off. With the A/C on, the fan will run.
Secondly, the coolant temperature starts to run at 100 degrees Celsius recently. Before this, it runs at 90 degrees Celsius. This is with the A/C on. Thermostat and radiator cap changed new.
Coolant temperature monitored using ScanGauge2.
Please help. Thanks.
Dec 20, 2018 at 8:24 PM
It sounds like the PCM is having an issue. But to be sure let's check for signal from the PCM to the control relay. Here is a guide and the cooling fan wiring diagrams so you can see how it works:
It looks like there are two fan can you confirm?
Dec 24, 2018 at 11:57 AM
