My radiator fan isn’t kicking on, only kicks on if I have the engine coolant temperature sensor disconnected. I’ve change the engine coolant temperature sensor I’ve change the radiator fan sensor switch I’ve change the oil engine sensor. I have put on a new serpentine belt and a pulley 2 expansion tanks, air mass flow sensor, transmission fluid, final stage resistor, and evap canister. The actuator motor. A new thermostat and a new water pump. The housing oil gasket, and some more stuff. I just can’t think right now. I have been worn down from trying to figure this out and not be more go anywhere in like six months. Please someone help me.
May 28, 2021 at 8:19 PM
