After replacing the left side cooling fan, it runs for about 10 minutes then stops?
1999 CADILLAC DEVILLE CONCOURS
120,000 MILES • 4.6L • V8 • AUTOMATIC
AZREDNECK
  • 6 POSTS
I replaced left side cooling fan it runs about 10 mins then stops?
Jul 13, 2023 at 12:49 PM
We need more details, is the engine overheating? Do you have a check engine light on? Is the fan running with the engine on or off? This cooling fan operation could be normal.
Jul 13, 2023 at 5:51 PM
AZREDNECK
  • 6 POSTS
Yes, it is running hot and the check engine light only after it overheats. It is left driver side fan new just replaced. I start up the car, turn the A/C on check both fans working after about 5 minutes. left fan stops and right A/C fan still works. Had a block test everything okay. Could thermostat be stuck closed? Thanks for your input.
Jul 14, 2023 at 8:43 AM
Yes, a stuck thermostat can cause this problem. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
Check out the images (below). Please let us know how it goes
Jul 14, 2023 at 9:44 AM
AZREDNECK
  • 6 POSTS
thanks, i will replace it.
Jul 14, 2023 at 10:08 AM
Please let me know if that solves the problem, have a good weekend.
Jul 15, 2023 at 10:12 AM
AZREDNECK
  • 6 POSTS
My left side fan only comes on when i turn on A/C. Then it stops after about 5 minutes. and will not come back on. the right side A/C fan keeps running.
Jul 17, 2023 at 9:55 AM (Merged)
What happened after the thermostat was replaced?
Jul 17, 2023 at 9:56 AM
AZREDNECK
  • 6 POSTS
I am still having problems, so the next step is to take it to a mechanic. Thanks for trying to help me. He will have the tools to find my problem.
Jul 17, 2023 at 10:47 AM
Did you replace the thermostat? Also, we should run the codes to see what comes up. It could be the engine coolant temperature sensor.
Here is the engine coolant temperature sensor location in case a code comes up for it.
Check out the images (below). Please let us know what you find.
Jul 18, 2023 at 10:00 AM
