Your car uses a coolant temperature switch to turn on the radiator fan relay. That switch has a single wire plugged onto it. It is a light green wire. Unplugging that switch would turn on the radiator fan by default on newer cars, but on yours, that wire must be grounded to turn the relay on. If the fan runs when you ground that wire, the rest of the circuit is working and the switch is suspect.
If the fan does not run when the switch is grounded, start by checking the 30-amp "radiator fan" fuse link. If that is burned open, the common suspect is the fan motor has tight bearings. Replace the motor, then the fuse link.
If you hear the fan relay click when you ground the light green wire, but the motor does not run, check for twelve volts going to the motor on the black/red wire. If you have it there, check the ground wire for continuity. If that is okay, suspect worn brushes in the motor.
If you do get the fan relay to click, but there is no twelve volts to the motor, suspect arced contacts in the relay.
Oct 25, 2020 at 11:43 AM
