Radiator cooling fan motor
2008 HONDA PILOT
162,000 MILES
THOMAS ROGERS2
Is the radiator cooling fan motor on the vehicle listed above interchangeable with any other Honda mode?
Nov 12, 2021 at 4:20 PM
I took some time and ran through a few other Honda vehicles and the part numbers are different. The OEM part number for your vehicle is 19030PVJA01. From what I am reading, that is the only vehicle it fits, other than a 2007 Pilot. The one for 2009 is different.
Is the fan not working? Have you checked it to confirm the motor itself is bad? I attached simple directions for testing them. You will just need jumper wires to power it. See directions below.
See pic below.
Nov 12, 2021 at 5:23 PM
THOMAS ROGERS2
You said that the ‘06-08 cooling fan motors were the same part number. my next question to y’all is, can I use any other year Pilot fan motor, or one from another Honda model and make it “fit” and won’t it work just as well? The replacement part new is over $300.00! Help me out here boys, isn’t there another Honda fan motor model that will do the job just as well?
Thanks for your thoughts, Thomas
Nov 15, 2021 at 7:09 AM
No problem. I didn't know that was what you wanted to do. Listen, there are likely others that will do the same thing, but at this point, I would contact a local parts store. They make universal cooling fans for all types of conditions.
Here is a link to AutoZone's info: Check it out. What to do is measure the fan motor/blades on your vehicle and find one that will work. These are universal fans, so mounting them will be done differently but they will do the job.
https://www.autozone.com/heating-and-cooling/universal-engine-cooling-fan
Sorry about that. I didn't know this was the goal. I thought maybe you had one from a different model year and was seeing if it was a direct fit.
Take care and let me know if there is anything I can do to help.
Nov 15, 2021 at 5:33 PM
