Radiator cooling fan?
2000 DODGE INTREPID
110,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
ANITA TROY
  • 38 POSTS
Trying to get the exact dual radiator cooling fan assembly with control relays (module) for my car. The car listed above is an rt model, and I hasn't been easy. I've ordered one assembly and it wasn't correct. Had no control relays on the assembly. So, I found one at rock auto and I'm hoping in their description I'm reading it right. If you could look for me in the attachment I'm sending and please tell me if this assembly has control relay with it. I would appreciate it greatly.
Jul 2, 2023 at 2:53 PM
Yep, you never know until you get the part, but this does look to be the correct unit. Here is the part number listed for your car in case you need it.
Fan Module 4596402AA $554.00
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jul 3, 2023 at 4:50 PM
ANITA TROY
  • 38 POSTS
I thank you so very much. I really hope the part I asked you about is the right one because I surely can't afford $554.00.
Jul 3, 2023 at 10:08 PM
ANITA TROY
  • 38 POSTS
Well, I had replaced my fan assembly not with a brand new one and my fans are still not kicking on. So, I checked all my fuses, and they all seem to be okay so I guess my next thing would to check out all the relays do you have a suggestion on which relays I should start with. Also, could you please tell me how to check a relay?
Jul 19, 2023 at 10:06 AM
Here are the fan wiring diagrams so you can see the fuses and relays involved.
Here is how to test the relays:
and to check for power:
Check out the images (below). Please let us know what you find.
Jul 20, 2023 at 10:37 AM
ANITA TROY
  • 38 POSTS
Okay, well, it starts out as I had my radiator replaced in my car the person that replaced the radiator did not connect my fan assembly to the radiator in which it had over time had you know fell into the pulley system and rubbed off all the wires to my fan, which my fan stopped working. My fan assembly has two relays on it, and I've had a hard time replacing it. so, I got one and I put it on, and my fan still doesn't work. So, I'm curious if when the wires all got rubbed off if it blew a relay or sensor or something. I checked all my little fuses, and they were all fine. So, my question is, would you have an answer on where I should start to check things? And could you tell me how to check a relay?
Jul 20, 2023 at 2:00 PM (Merged)
Please check the post above and get back to us.
Jul 20, 2023 at 2:01 PM
