Radiator and pipe
2006 VAUXHALL ASTRA
127,000 MILES • 1.7L • 2WD • MANUAL
BGODDARD13
I've recently had a new radiator on my vehicle and recently the hot water pipe that goes into the radiator keeps popping off, then the car is running so all the water comes out. I've recently put jubilee clips on it instead of the old clip but it doesn't keep to of worked because it keeps popping off.
Dec 23, 2019 at 8:38 AM
If the radiator cap isn't releasing pressure, it can cause it to happen or the hose may be worn and not longer able to stay attached. Have you tried replacing the hose? If you do, make sure where it connects is clean and dry.
Dec 24, 2019 at 12:02 AM
