Hey,
I took my car to a mechanic, and they said I needed a new engine. This was in line with the diagnostic of another mechanic, so I went with it.
But then they said I also needed to replace the radiator as they found a hole in it, so it was leaking. That was a surprise as I just replaced it myself not long ago and there was no leak then, whatsoever. They went on to explain that I bolt I used to attach it, was too big so it pierced through. They eventually showed me that bolt and it was a size 10, instead of size 8.
I don’t understand how this could have happened as I took back home my old radiator and the size 10 bolt. I tried several times to pierce through the mounting pipes of the radiator with that bolt, but it’s not going through at all.
I need help here, please. I explained it to the manager of the shop but that went nowhere. I was charged for the radiator replacement.
So, my question is: is their explanation for the cause of the leak legit? Or did I get played?
Thanks for the response.
Aug 1, 2023 at 12:02 PM
