I took my van in to the Dodge dealer for an oil change. then I get the message saying my car needs repairs.
It needs a new gasket $216.00 The coolant reservoir is low I think we should do a pressure test to start to see if there are any leaks. If there are not any we should flush the coolant $220.00 The air filter is dirty $26.00 The brake fluid is dark as well and should be flushed $185.00.
I told them it was okay to do the gasket when I went to pick up the car they said that one of the hoses was leaking coolant and they needed to replace it.
5 days later after I picked up my van the next morning I drove my car 30 miles from home. And find that there was coolant on the ground where I had the car parked. And in my driveway.
Dealer said that the radiator side tank blew and that it was not their fault.
Could the repair the dealer did have cost the radiator to break?
I have spoken to four different mechanics that said that It looks like the dealer did not bleed the system correctly after the repairs they did.
Aug 22, 2020 at 8:00 PM
