Radiator
1998 VOLVO S70
158,453 MILES • 2.4L • 6 CYL • AWD • AUTOMATIC
BRAD75
When driving it does not get hot. But when I turn off the car it gushes out coolant.
Aug 16, 2016 at 12:55 PM
The coolant boils over because the engine is hot, I would do a coolant drain and fill and check for a blown head gasket
here are some guides to help you.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
and
Please let me know what you find
Best, Ken
Aug 19, 2016 at 9:08 PM
BRAD75
Ok thank you. I found it only does it after I use the A/C. It hasn't done it since I stopped using it. Would that still be what to do?
Aug 19, 2016 at 9:15 PM
SATURNTECH9
  • 30,869 POSTS
So does the AC ever start blowing hot when you were using it? Also is the AC/radiator fan working with the AC running? Does it ever overheat with the AC ON? also how old is your radiator cap?
Aug 20, 2016 at 3:35 PM
