Is there any evidence of coolant on the ground after the vehicle sits over night? Is there any white smoke from the exhaust when the vehicle is running?
It could be from a number of different things. If you are seeing white smoke from the exhaust, there is a chance coolant is getting into the combustion chamber. When it burns with the fuel, it produces a white smoke out the exhaust.
Take a look at this link. It explains how to check for a bad head gasket.
If you are seeing any evidence under the vehicle, take a look through this link and see if it helps:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know if the links help. Also, let me know what you find or if you have other questions.
Oct 25, 2020 at 6:50 PM
