Hi, the leak is at the fitting connection, of the small high pressure line on the assembly itself, which runs from the main housing, to the center of the assembly. I have not been able to find out if this line can be replaced or can I cannibalize a used assembly to replace only the line. I want to avoid replacing the entire rack and pinion assembly, which for this issue, should be possible. Tried to add an image, but does not seem to be working.
Thanks,
Joe C
Thanks,
Joe C
Sep 23, 2019 at 11:03 AM
