I am not located in the USA. I am planning to buy and replace the steering rack. The original steering rack number for my car is GM 26046148. The original rack is with variable effort steering (option NV7), with soft ride suspension (option FE1).These parts are not available, but there are modern analogs. For example, Cardone 22-108, Cardone 22-137. I have two questions.
Question 1: Will Cardone 22-137 (with Performance Suspension) fit my car suspension (with soft ride suspension, FE1)? (https://www.cardone.com/search.php?search_query=%22NSXBD3M~%22&year=1993&make=OLDSMOBILE&model=ACHIEVA&Part%20Type=Rack%20and%20Pinion%20Assembly&sort=relevance).
Question 2: Which shaft size should I buy?
Cardone 22-137: Input Shaft Diameter - Imperial: 0.66 in;
Cardone 22-108: Input Shaft Diameter - Imperial: 0.79 in (https://www.cardone.com/compare/82865/76287/82865/76287).
Please use the two links provided here.
Nov 3, 2022 at 12:09 AM
