When the rack is leaking a tiny bit or a lot, that's due to the fact that the power steering wheel fluid is probably black instead of red and needs to be flushed out and bled?
If the answer is yes to the above question, can the power steering fluid be flushed out, replaced and bled without replacing the Rack and Pinion or is it recommended to just replace the Rack first?
Dec 3, 2019 at 3:17 AM
