I changed the right-side blend door actuator behind glove box, the old one had a strip gear.
I removed the driver side actuator and took it apart and it had no striped gears in it. Is it possible that there is still something wrong with it like the motor? Should I replace it?
I did the reset, pulling fuse for a min and powering up in acc mode for a min, then started and left everything off for another min.
When I put it into dual control and turn the right side, all the way up to 90° the right side it seems to be a little lower temperature than when it is set at 67°
Thanks for your help.
Jun 18, 2023 at 9:40 PM
