Turn signal blinking fast
2015 KIA SOUL
35,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SPENCENVICKIE
  • 29 POSTS
My turn signal was blinking fast so I knew I had a burned out bulb. The front turn signal bulb went out, so I replaced both front and rear turn signal bulbs at the same time. However, the blinker is still blinking fast. Both signals are working, but blinking fast and only on that side. Any suggestions?
Dec 18, 2020 at 12:05 PM
Are all of the lights lighting up when it flashes fast? Are you sure the correct bulb was used? Also, do you have signal lights on the exterior mirrors? Also, I believe there is a side indicator light as well.
The idea that it is flashing fast is an indicator of an open circuit (meaning a bulb is bad).
Let me know about the mirrors. If you have to replace one of them as well, here are the directions. The side signal lamp is included as well.
_____________________________
2015 Kia Soul L4-1.6L
Turn Signal Lamp
Vehicle Lighting and Horns Turn Signals Turn Signal Lamp Service and Repair Removal and Replacement Turn Signal Lamp
TURN SIGNAL LAMP
SOUL(PS) 2015 G 1.6 GDI Body Electrical System
Removal
Door Mirror Turn Signal Lamp
1. Disconnect the negative (-) battery terminal.
2. Remove the mirror holder (A) from the outside mirror assembly.
pic 1
3. Remove the door mirror cover (A).
pic 2
NOTICE:
Be careful not to damage the fixing clip
4. Loosen the mirror turn signal lamp mounting screw (A).
pic 3
5. Remove the door mirror turn signal lamp (B) after disconnecting the connector (A).
pic 4
Side Repeater Lamp
1. Remove the side repeater lamp (A) from the fender.
pic 5
2. Disconnect the connector (A) from the side repeater lamp.
pic 6
3. Remove the bulb (A) from the side repeater lamp.
pic 7
Installation
1. Install the door mirror turn signal lamp.
2. Install the door mirror cover.
3. Install the door mirror.
4. Connect the negative (-) battery terminal.
Side Repeater Lamp
1. Connect the connector and install the side repeater lamp.
_______________
Dec 18, 2020 at 8:28 PM
SPENCENVICKIE
  • 29 POSTS
Thanks for the info. I double checked all the bulbs this morning and tested the front turn signal bulb and, sure enough, one of the two filaments was shot. Not sure how, since that was a new bulb and I don't really think of a new bulb blowing a filament, but I replaced it again and it's all good.
Thanks for the help. Have a great holiday season.
Mele Kalikimaka and Hau'oli Makahiki Hou! (Merry Christmas and Happy New Year in Hawaiian)
Dec 20, 2020 at 11:11 AM
I'm glad you got it fixed. Honestly, you would be surprised how many bulbs are bad when purchased. LOL Anything to make things just a little more difficult.
If you are in Hawaii, I envy you. It's 20° here in non-sunny Pennsylvania.
Buon Natale e Felice Anno Nuovo, which is Merry Christmas and Happy new year in Italian, where my family is from. And although I can't pronounce what you wrote, it looks like it would sound really nice.
Take care of yourself. Please feel free to come back anytime in the future if you need help or have questions. You are always welcome.
Dec 20, 2020 at 9:30 PM
