I am happy you understand the importance of safety, including jack stands. How you support the truck can depend on the type of work you are going to do. If you are going to be doing steering and suspension-related work, you may need to let the wheels hang down so they are not holding the truck up. Sometimes you need to put the jack stands under the front lower control arms so parts like the front half shafts are easier to remove. On the rear, the shock absorbers are what limits how far the axle assembly can drop. If you are replacing those shock absorbers, you will need to put the jack stands under the axle housing so there is no tension on the shock absorbers.
The most solid place to put jack stands is under the frame rails. Uni-body cars do not have frames, but they have the equivalent of frame rails that will support the vehicle, as long as they are not rusted away.
You have rear leaf springs for the rear axle. You can put jack stands under them too, but be aware they are often sloped or not parallel to the ground, and their angle can change as the truck is raised and lowered. These are my least favorite place for jack stands due to the possibility of them sliding out.
If you have the owner's manual or the service manual for your truck, it will show where to jack it up and where to put jack stands. Tow truck drivers have books too that show the hooking and lifting points.
Jack stands actually serve two purposes. One is to support things in the right way to allow the service work to be done, and the other is safety. When you start tugging on wrenches and pry bars, the truck must be sitting solidly on the stands so you cannot pull it over, and if a lifting device fails or squirts out and the truck falls, the jack stands must be in an orientation that prevents you from becoming a pancake!
Take a look at this article that provides a lot more information on this subject:
Jul 22, 2018 at 6:37 PM
