After replacing Mass Air Sensor check engine light turned on
2000 BUICK REGAL
138,000 MILES • 3.8L • 6 CYL • AUTOMATIC
JULIE A ZAMBON
put mass air sensor in, check engine light came on 2 days later. going home and it would barely run. shifted down to third and got it to mechanic. code is 1.
Oct 16, 2019 at 3:11 PM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros. What was the reason you replaced the MAF for? Any codes or CEL prior to replacement? Is the replacement part a new OEM or after-market piece?
How was it running prior to the replacement part?
Oct 16, 2019 at 3:23 PM
JULIE A ZAMBON
whining noise and then it would jerk.
Oct 16, 2019 at 3:28 PM
JULIE A ZAMBON
ac delco part. my machanic wont use after market parts!
Oct 16, 2019 at 3:29 PM
STEVE W.
  • 15,113 POSTS
So before the part was replaced it would whine and then jerk? Did it shut down or have other problems? Is the check engine light on now? Do you have a way to scan it to get the codes?
Oct 17, 2019 at 12:52 AM
