Installing a push to start and stop button, can I get a color code wiring diagram for the ignition switch?
2008 CHEVROLET IMPALA
202,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
CLOCKMEISTER420
MEMBER
FOLLOW
I need a color code wiring diagram for the car listed above for the ignition switch, so I can wire in a aftermarket push to start and stop button.
Aug 17, 2023 at 12:49 AM
CERTIFIED EXPERT
Sure, here is the ignition switch wiring diagram so you can see how the system works and how to wire the aftermarket push to start and stop button. This guide will help you test the connections:
