Purge valve?
2004 HYUNDAI SANTA FE
260,000 MILES • AUTOMATIC
NICOLE FERGUSON-TAYLOR
HELLO , so my vehicle will not start after refueling, I have to rev the engine. it even dies out a couple times if I do not rev enough and start driving quick enough. AS well I have had the tank over flow when fueling sometimes! What I have read it the purge valve is probably causing the starting problems and the vent valve is causing the fueling problems ! I have booked an appointment to get my purge valve changed based on this. Do you think that is most likely the problem ?
May 4, 2016 at 12:27 PM
HMAC300
  • 48,601 POSTS
this can be anything if you were very low on fuel when you filled up then it may have locked up the fuel pump. then worked but with low pressure. the will find it when they look at it.
May 4, 2016 at 1:04 PM
its been looked at and said nothing was wrong with it yet the problems keep happening! That is why I'm on here trying to get answers ..
May 4, 2016 at 1:14 PM
CAR-MAN145
  • 321 POSTS
I would agree that it is the purge solenoid and vent valve for the problems you are having
May 5, 2016 at 1:15 AM
